Under construction
Attain: Default language settings for all projects of my organization
  • 27 July 2021
  • 19 views
Userlevel 1
Badge
Please could you investigate about the possibility to define a default language setting based on an organization. In our example, we only need the German language (base language) for our projects. No “localizatio”/translation needed. But for each setup of a project we need to define / change  the language settings. If you have mulitple authors, it’s time consuming to control this and an unnessecary effort in our case.
I assume that all organization with a single base language other than “English” have the same issue.
Please investigate into the feature request.
@Community, if you feel the same, please join in.
Userlevel 4
Badge
Thanks for reaching out. We will be supporting this with a templated approach to creating new projects. This will allow you to clearly define your baseline for all new projects.
Reply
