Recording always 2cm further up than selected location
  • November 15, 2022
  • 40 views
Hi there,
I am trying to insert Steps to a existing Recording. But is marks always 2cm up than the selected button or field (See image). Anyone know why this happens?
Thank you for your help!
KR, Sivi
Hi Sivi,
Perhaps you are using Chrome? we currently have an issue in the latest chrome build, we are working to fix it - but until then, you can use Microsoft Edge instead :)
  • November 15, 2022
Hi Sivi,
