Attain: ClickLearn Studio version 12 (or newer) minimum system requirements
  • Sep 25, 2020 10:55 AM UTC
  • Sep 8, 2026 10:30 AM UTC
  • 924 views
Operating System
  • Windows 7 or later, 64-bit
Note: Will not work on Windows 8.0
Running ClickLearn on Mac
ClickLearn is a Windows-native application. To use it on a Mac, run it inside a Windows virtual machine (VM).
Recommended Mac Host Specifications
Component
Specification
Processor
Intel or Apple Silicon with 8+ cores
Memory (RAM)
24 GB (minimum 16 GB)
Storage
256 GB SSD with 100 GB+ available
VM Allocation
Resource
Allocation
CPU cores
4–6 cores
Memory
16 GB RAM
Storage
100 GB+ (Windows OS ~20–30 GB, plus ClickLearn, Microsoft Office, cache, and project files)
Windows Licensing
A valid Windows 10 Pro or Windows 11 Pro license (retail or volume) is required inside the VM.
Virtualization Software
  • Parallels Desktop (recommended - best performance on Apple Silicon)
  • VMware Fusion (paid / free for personal use)
  • UTM (free, open source)
  • VirtualBox (free, Intel Macs only)
Setup Steps
  1. Install your chosen virtualization software
  2. Create a new Windows 10/11 VM with the resources above
  3. Install Windows and activate with your license key
  4. Install ClickLearn and any applications you plan to document
  5. Activate your ClickLearn license
Performance Tips
  • Close unnecessary Mac applications while running the VM
  • Enable hardware acceleration in VM settings
  • Store project files on the VM's virtual disk
  • Allocate more RAM to the VM if you experience slowdowns
Note for Apple Silicon Macs (M1/M2/M3/M4): make sure your virtualization software supports ARM-based Windows, or can run x86 Windows with acceptable performance.
Dependent Software
  • .NET Framework 4.8 or above
  • Microsoft Edge must be installed
Hardware
  • Minimum 10GB available HDD storage
  • Minimum dual-core CPU (1.5 GHz or higher), recommended 4-core CPU
  • Keyboard with two ctrl keys recommended, and mouse (using raw input)
RAM Requirement
  • Minimum 16 GB RAM
Network
Whitelist the URLs for your application's hosted region from your firewall. Replace [ORG NAME] with your organization name.
EU
https://[ORG NAME].portal.eu.clicklearn.com
https://[ORG NAME].portalapi.eu.clicklearn.com
https://[ORG NAME].content.eu.clicklearn.com
https://uploadv8-westec.clicklearn.com
https://portalapi.clicklearn.com
https://portal.clicklearn.com
https://apps.clicklearn.com
https://lookup.stampregistry.clicklearn.com
https://upload.clicklearn.com
US
https://[ORG NAME].portal.us.clicklearn.com
https://[ORG NAME].portalapi.us.clicklearn.com
https://[ORG NAME].content.us.clicklearn.com
https://uploadv8-ncenus.clicklearn.com
AU
https://[ORG NAME].portal.au.clicklearn.com
https://[ORG NAME].portalapi.au.clicklearn.com
https://[ORG NAME].content.au.clicklearn.com
https://uploadv8-aueast.clicklearn.com
CA
https://[ORG NAME].portal.ca.clicklearn.com
https://[ORG NAME].portalapi.ca.clicklearn.com
https://[ORG NAME].content.ca.clicklearn.com
https://uploadv8-ceca.clicklearn.com/
Live document:
https://help.content.eu.clicklearn.com/publiccontent/ClickLearn%20Product%20Documentation.1033/installation-and-configuration/minimum-requirements-for-using-attain
