Tutorial
Attain: Keyboard shortcuts
  • Jul 6, 2021 8:50 AM UTC
  • 359 views
The following list contains all available keyboard shortcuts from inside ClickLearn Attain.
General Shortcuts
Ctrl + X » » » » » » Cut
Ctrl + C » » » » » » Copy
Ctrl + V » » » » » » Paste
Ctrl + Z » » » » » » Undo
Ctrl + Y » » » » » » Redo
Ctrl + F » » » » » » Global Search
Ctrl + Shift + P Report a Problem
Global Search
Esc » » » » » » » » » » Close
Enter» » » » » » » » » Open
Ctrl + ⬆️/⬇️» » » Navigate Up/Down
Project list
Ctrl + R » » » » » » Refresh
Recording List
Ctrl + A » » » » » » Select All
Enter» » » » » » » » » Edit Recording
Delete» » » » » » » » Delete Recording
Ctrl + I » » » » » » Import Recording
F5 »  » » » » » » » » » Replay
Ctrl + D » » » » » » Download
Editor
Alt + F4 » » » » » » Close
Ctrl + S » » » » » » Save
Structure
Ctrl + P » » » » » » Preview
Delete  » » » » » » » Delete
Assets
Ctrl + I » » » » » » Import Asset
General Shortcuts
Localization Shortcuts
Ctrl + Shift + A Run Analyzer
Ctril + T  » » » » » Auto Translate
F5 » » » » » » » » » » » Replay
Settings
Translate Dialog
Ctrl + Enter» » » » Save And Close
Ctrl + Tab » » » » » Switch Language
trice602
Forum|alt.badge.img+2
  • Jul 16, 2021 8:14 PM UTC
Nice!  Saving this! :grinning:
Thanks for the list.  I am looking specifically for the hotkeys while recording… Pause, Resume, Screenshot, etc.
  • Apr 29, 2024 7:04 AM UTC
When you are recording, there is just one shortcut you need to use, and that is CTRL + CTRL (Press both Control/CTRL keys on your keyboard).
This will bring up the recording panel, where you can both pause and navigate to another context in the application where you are recording, you can take screenshots and also add chapters and notes while you are recording.
NOTE: If you have a keyboard with only one CTRL/Control key - like the Microsoft Surface and others - then you simply place the cursor in the TOP-LEFT corner of the screen and then press CTRL + SHIFT instead.
