Could not record for WinAutomation using WINUIA
  • Sep 14, 2020 10:36 AM UTC
  • 66 views
WinAutomation is the windows application developed by softomotive. and it becomes a part of the microsoft power automate since May 2020.
I tried to create a recording using Windows UI connector. however nothing captured.
I would like to ask you to add feature to support Winautomation in next release.
Best answer by Tobias
Hi Jaden,
Thank you for your post.
As explained in our online meeting this is right now not supported but we will suggest it to our DEV-Team so it  might be at later stage but cant promise :-)
Tobias
Senior Support Consultant
  • Senior Support Consultant
  • Sep 14, 2020 10:08 PM UTC
Hi Jaden,
