Is there a way to export all Clicklearn Articles and metadata
  • Dec 8, 2022 10:38 PM UTC
  • 77 views
Is there a way to export all of the ClickLearn articles on the cloud Published contents to a local computer
Hi Jarred,
Sure, if you login to your portal - or just go directly in Attain under settings - published content, then you can download it :)
  • Dec 9, 2022 9:20 AM UTC
Hi Jarred,
Thanks! Though I don’t seem to have that many options on my options there “...” will check the link as well that you posted.
  • Dec 15, 2022 4:16 PM UTC
Hi Jarred,
Please try from within Attain itself :)
