Move recordings between projects
  • October 12, 2023
  • 82 views
Hi. Please advise whether it is possible to move recordings from one project to another. ‘Move file to’ only seems to allow movement within a project rather than between projects.
  • October 13, 2023
Hi Tracey,
You can use the import feature for this, or you can download the recordings and manually drag and drop then into the new project.
Then you can delete them from the old project if you please :)
