Quick Parts in MS Word
  • Aug 9, 2025 1:30 AM UTC
  • 62 views
Hello,
can anyone point me to a list of the Quick Parts field in MS Words and their relative Metadata Tags in ClickLearn.
Thanks Penny
Best answer by ClickLearnProductTeam
Hi ​@pennyelson
Thank you for posting on our community!
To find the list of properties in MS words you can follow these steps:
  1. Enable metadata in your project (if already enabled you can skip this step)
  2. In a MS word file, go to Info tab
  3. When you click on properties, you’ll find Advanced Properties
  4. In the pop-up, under the tab “Custom”, you’ll be able to find a list of relative ClickLearn Metadata tags starting with cl------ as shown below.
Hope this helps!
Hi ​@pennyelson
Hope this helps!
