Remove left/right navigation to next recording on portal
  • Feb 13, 2026 7:01 PM UTC
  • 32 views
Is is possible to remove the left/right navigation to next recording on the portal so that they are not visible?  Feedback from some users were they ended up in another recording by mistake.
Best answer by Plamena
Hi ​@Michael Padazis,
Thank you for posting on Community!
At the moment, it is not possible to remove the left/right navigation buttons in the Portal. These are part of the standard navigation experience. We appreciate the feedback and understand it can be inconvenient for your end users. If this is something you would like to see changed in the future, you are welcome to submit it as a feature request in our Ideas portal:
Ideas & Feature requests
Our Product team regularly reviews submissions there when considering enhancements.
Please let us know if there is anything else we can assist with.
BR
Plamena
  • Customer Support Lead
  • Feb 18, 2026 2:10 PM UTC
BR
