Returning to a project and adding further steps
  • Jun 16, 2022 6:42 AM UTC
  • 104 views
Hi, I was wondering if it’s possible to return to an old project and add some steps to what has already been recorded. We save as SCORM and both the pdf and Try me options are used in equal measure - how could I do this rather than re-recording from scratch?
TIA
Hi James,
you can always edit the recording files if you have them still.
you can reach out to us at support to schedule a session, then we can look at it together :)
  • Jun 16, 2022 8:05 PM UTC
Hi James,
