Stopping recording without ctrl+ctrl
  • November 14, 2022
  • 208 views
Hello,
Could you please advise on how can I stop the recording without using ctrl+ctrl? I have a french keyboard (azerty) and I have only one ctrl on my keyboard. Thank you in advance,
Aleks
Hi Aleks :)
you can hold ctrl+shift and while holding them, move the mouse into the top left hand corner of the screen - keep moving the mouse into the corner, as if it was infinite.
That is the same and holding two control keys, mac users do it too! :)
  • November 14, 2022
Hi Aleks :)
  • November 14, 2022
Hello Morten,
Thank you for your answer, now it’s clear :)
Aleks
  • November 14, 2022
Hello Morten,
Aleks
you are welcome :)
