Using Clicklearn for APT of IFS Aurena
  • Jun 27, 2023 1:47 PM UTC
  • 5 replies
  • 160 views
Hello,
Is using Clicklearn for Automated Process Testing of IFS Aurena supported?  If this is supported, are there any qualifiers/caveats?  Basically, a use case document would be helpful.  Or possibly even a demonstration video.
Thank you for considering my question.
Kind Regards,
Marc
Hi @iam0kru
There is no video with APT specifically for aurena or cloud.
APT is APT - the concepts are the same across all applications supported by ClickLearn.
yes, APT is supported for Aurena and IFS Cloud :)
  • Jun 27, 2023 2:21 PM UTC
Hi Marc,
APT is support for all our connectors.
Documentation for APT can soon be found on the universe, but for now - you will find a lot of videos in the masterclass section of the community for this.
if you would like to look at it on a session, go ahead and contact your CSM or our support team.
br, Morten
  • Jun 27, 2023 3:53 PM UTC
Thanks Morten, just to be clear.  APT can be done for Aurena?
Also, I checked the Masterclass area and didn’t see any videos showing APT for Aurena.  The specific functionality regarding APT I am looking to confirm is Clicklearn works for Aurena.
  • Jun 28, 2023 9:35 AM UTC
Hi @iam0kru
  • Jun 28, 2023 11:46 AM UTC
Thanks again Morten.  You are always awesome to deal with!
  • Jun 28, 2023 11:48 AM UTC
hey no worries, and thank you!.
If you have issues with your APTs - reach out :)
