ClickLearn Analytics - expertly use the ClickLearn Analytics system in Power BI
  • Nov 16, 2022 2:40 PM UTC
  • 294 views
Did you know… that ClickLearn Attain has a wealth of information to mine from the Dashboard metrics inside any project? Okay, maybe you did BUT did you also know that you can pull that information into a Power BI dashboard? If your company likes to slice and dice the details of your end user’s adoption of your super application(s), come check out how using the OData feed works to bring your data to life in your nicely crafted BI dashboard!
In this session we will take a look at:
  • Where you can access the Odata feed inside your project
  • How you can bring the data to life using Power BI basic components
