Create a small sub-section in written material
  • Dec 15, 2022 2:34 PM UTC
  • 56 views
How can I create a small sub-section in the written material?  In the example below, I can eliminate section 1A from the flow with a question, but in the written material, I can’t figure out how to break out just these three steps into a section without the rest of the flow being under this section
Hey @Laura Blum :)
i think its easiest to look at it together in the editor, can you email us at support? then we can set up a session.
  • Dec 15, 2022 10:23 PM UTC
Hey @Laura Blum :)
