Deletion items and Bin
  • November 18, 2024
  • 40 views
Good morning,
Just a thought, if I delete by mistake a file, project, recordings… is there a bin where I can retrieve the items deleted?
Thanks
Cathy
Hi ​@Cathy Tucker :)
When you go to your portal and click the recordings tab, you can click on “view lost files” or you can go into your project and select “recover lost files”.
  • November 25, 2024
