Inside Help, Forms and Entities Removal
  • December 22, 2021
  • 106 views
How do you remove the Inside Help, Forms and Entities from the ClickLearn Shelf?
Hi Emily :)
You can’t directly remove it, but you can create chapters on the shelf.
The last chapter you create will contain those three items.
  • December 22, 2021
Hi Emily :)
