Inside Help Project but no Connectors available
  • Feb 9, 2023 11:52 PM UTC
  • 116 views
EzzyPidcock
Enthusiast
Hi There,
I am trying to create a project under ‘Inside Help’ and when i progress through and get to where i select the ‘Connectors’ there are none available to choose and i can’t proceed.
Any ideas why?
Best answer by Peter Højlund Løvskov
Hi EzzyPidcock,
The Inside Help project is only available for Microsoft Customer Engagement and Microsoft Business Central platforms.
So only if you have one of these two connectors in your license configuration, will you be able to select a connector under this project type.
I can see that your organization, does not have Microsoft CE or Business Central in your license configuration and therefore you can’t choose one.
But let us know if you need to do any documentation for either platform.
I hope this helps and answers your question.
Kind regards,
Peter.
Training Manager
Hi EzzyPidcock,
Kind regards,
Peter.
EzzyPidcock
Enthusiast
  • Feb 12, 2023 10:41 PM UTC
Hi Peter,
That makes sense!
We predominantly use the IFS and O365 Connectors so wont be able to take advantage of the Inside Help function - damn!
Thank you for your response.
Erin
  • Apr 20, 2023 3:34 PM UTC
Hi @EzzyPidcock
You can use the assist extension to enable in-app assistance and also trigger the learning portal directly - it is not a field contextual inside help, but its somewhere inbetween :)
EzzyPidcock
Enthusiast
  • Apr 20, 2023 11:11 PM UTC
@Morten thats a great suggestion - thank you
