Is there a way to call attention to a field without having to click in it?
  • Sep 23, 2020 1:53 PM UTC
  • 2 replies
  • 191 views
hmccabe
Forum|alt.badge.img+1
Sometimes in a course I want to point out or call attention to a field or the data in the field but do not need the user to actually click in the field or take any action. Such as pointing out that the data in the field changed.
Is there an action, like a mouse hover, that will do that?
Hi @hmccabe yes! you can use the “mouse move” function :)
while hovering over the field, once the green rectangle appears click the left CTRL+SHIFT - the green rectangle will then disappear and reappear, indicating that the step was captured.
if you accidently click something, you can use the mouse action menu to change your click type, like so:
right-click a step in replay role
  • Sep 23, 2020 2:01 PM UTC
trice602
Forum|alt.badge.img+2
  • Apr 22, 2021 3:57 PM UTC
Excellent!  I forget some of the functions and features and this community portal has helped me solve a lot of stuff!  Thank you! :grin::grin::grin:
