Issues with Asset Display and Reusing Recordings Across Languages
  • Jul 25, 2025 11:25 AM UTC
  • 2 replies
  • 84 views
Hi everyone,
I'm currently working on the translation of my trainings and keep running into issues:
  1. When a recording (content blocks with image), for example, contains 10 assets (e.g., images), and a different language is selected, only one asset is shown across all recordings instead of the full set. However, when looking at the source, the correct assets are actually there. It’s just that only the first of the 10 is displayed.
  2. Some recordings are set to be replayed, but I’d like to reuse the same recordings for other languages as well (video mode only - no assistant). Even though I choose to ignore the translation, it still doesn’t work as expected.
To 1: Why is this happening, and what can be done to fix it?
To 2: Is there a way to make this work without having to duplicate or re-record the videos for each language?
Thanks in advance and best regards,
Hona
  • Jul 25, 2025 11:31 AM UTC
I found the solution for the first issue:
Plamena
  • Customer Support Lead
  • Jul 25, 2025 7:38 PM UTC
Hi ​@JEHPE ,
Thanks for sharing this — and great to hear you have found a solution for your first question!
To help avoid any unnecessary back and forth and to ensure we fully understand what you are aiming to achieve, we would recommend reaching out directly to our support team at support@clicklearn.com. They will be able to take a closer look at your setup and advise on the best approach for reusing recordings across languages in video mode, especially with your goal of avoiding duplication or re-recording.
We are happy to support you in finding a streamlined solution for your multilingual content setup.
Best regards,
