OR Option in Flow Editor
  • Dec 15, 2022 2:25 PM UTC
  • 83 views
Is it possible to make an OR option in the Flow editor?
For example I have the following flow:
Is the BO for company 707? Y/N
      If the answer is No, then ask Is the currency USD? Y/N (This question is skipped if the company is 707)
Later in the process, I need to check, IF the company is 707 OR the currency is USD do these steps.
Hi @Laura Blum
you can have a question trigger another question or use some of the additional options for qualification.
When you write us regarding the section editing, lets look at this too - there might not be an OR, but perhaps we can find a good way to solve this :)
  • Dec 15, 2022 10:27 PM UTC
Hi @Laura Blum
