Recording Audio
  • Nov 3, 2020 5:18 PM UTC
  • 6 replies
  • 250 views
kyliekiser
Forum|alt.badge.img+5
We have some new use cases for ClickLearn within our organization and one group would like to record their own audio for the steps. Is this possible?
Thanks!
Best answer by RichardPower
In Developer mode (ClickLearn Classic) the editing pane has a “Custom Audio” area near the bottom. I’ve never tried it, but that’s where I would start. It has a record on/off button so you can do it there, and it looks like you can import external audio files as well.
Forum|alt.badge.img+2
  • Nov 3, 2020 5:23 PM UTC
  • Nov 3, 2020 5:28 PM UTC
Hi Kylie,
they definately can :) they can either add the pre-recorded audio files directly on the steps, or they can record them directly at the relevant step.
I’ve attached the guide.
Lars Heinrich
Training Manager
  • Training Manager
  • Nov 3, 2020 7:58 PM UTC
Hi Kylie,
It certainly is an option but be aware that it will require manual maintenance going forward – so keeping the documentation updated will require a lot of work compared to just replaying the recordings.
BR Lars
beauj9
  • Aug 11, 2021 7:31 AM UTC
Hi Community,
I am looking for a way to record voice over for the entire recording, rather than just change custom audio for specific steps.  How can I just record using the microphone for the entire video??
If anyone knows how to do this, please let me know.
Thanks!
Jim Beaudoin
Austal Ships Ltd.
  • Aug 11, 2021 8:05 AM UTC
Hi @beauj9 !
Excellent question. The main benefits of using ClickLearn - automated combining of text and screenshots with digital voices to create 7 formats of learning and documentation - will be difficult to achieve in the scenario you describe above. Authors risk spending a lot of time to try and make the perfect audio recording and match the timing with the steps in the video. This type of video/audio recording and editing capability is outside of the scope of the solution.
We recommend using the digital voices to create automatically narrated videos. This also makes it a lot easier to maintain and update your source content when needed. In the rare exception where you might need to record or insert your own audio, this is as you also write only possible on step level. But generally I would suggest avoiding it whenever possible.
beauj9
  • Aug 13, 2021 5:03 AM UTC
Thank you Per;
I understand both the limitations and the advantages of using the digital voices to more easily update source content later.
Thanks very much,
Jim Beaudoin
Austal Ships
Perth Australia
