Recordings not showing up in content portal after being published in ClickLearn Studio
  • Apr 18, 2023 12:54 PM UTC
  • 7 replies
  • 184 views
I’ve tried to publish several times the content but after doing so, I go to the Content Portal and it doesn’t show any of the new recordings I’ve tried to previously publish.
It seems as if, the Content Portal doesn’t change at all, and doesn’t add or remove anything that I do in ClickLearn Studio.
This started happening since the new version came out.
Hi  @Ines Sousa
sorry to hear you are having issues.
after producing, did you select the newest version from the stack and chose “set as active version” ?
  • Apr 18, 2023 1:21 PM UTC
Hi  @Ines Sousa
I’m having trouble with this also, and I’ve already confirmed what they suggested by having it as the Active Version. They still don’t show up.
  • Nov 9, 2023 2:59 PM UTC
Hi @Dona Wallerius
reach out to us on support and we can do a remote session to look at whats up :)
I’ve already sent a request to support for help.  Haven’t heard back yet.
  • Nov 9, 2023 3:09 PM UTC
I see your ticket, i will have my colleague respond to it asap.
Michael contacted me and we got it figured out.  I wasn’t aware that I needed to go to the structure and drag the files into the proper folder.
  • Nov 10, 2023 8:51 AM UTC
great to hear :)
For others with similar issues, this will be helpful :)
https://universe.clicklearn.com/Modules/ViewModule?id=e945fc55-94b0-49a2-9cf5-f094762581c2
