Setting different voices for modules
  • May 9, 2022 9:12 AM UTC
  • 5 replies
  • 138 views
Debra-Derieux M
Explorer
I have created two eLearning projects for specific training that contains modules/lessons created by different SME’s and I would like to set the voice gender according to the SME’s gender.  Can I select a different voice for each lesson?  Or is it only per project?   Please help!
Hi @Debra-Derieux M
This can be done, yes.
In order to accomplish this, you just need to create two templates, one with each voice setting - and then apply the template to the applicable recordings in your structure.
This is where you modify the voice for each template individually:
Once you have those two templates in place, you can apply them to the recordings in the structure editor:
  • May 9, 2022 9:49 AM UTC
Hi @Debra-Derieux M
Debra-Derieux M
Explorer
Fantastic!  I think I understand 🤔.  I will give it a try!  Thank you Morten!
  • May 9, 2022 4:20 PM UTC
anytime :)
Debra-Derieux M
Explorer
@Per hi, thank you for your reply on this question.  @Morten mentioned I can create a separate template with female voice for the training modules that have been created by a female SME from our team.  Which option should I try?
  • May 10, 2022 4:08 PM UTC
Hi @Debra-Derieux M Debra,
If you have issues making it work, then send us an email here on support (at) clicklearn.com and we can show you on a meeting :)
