System Shortcuts
  • Sep 18, 2023 4:28 PM UTC
  • 48 views
Forum|alt.badge.img+1
Back in March 2022 you showed me how to remove the shortcuts that CL captured when recording from our POS system.
I would like to turn these back on.
I am not looking to use the CL shortcuts but the ones related to our POS system.
Can you tell me how to do this please?
  • Sep 19, 2023 8:03 AM UTC
Hi Lorie,
If you make a new project, then import your recording - and edit the template entry for a step that has a shortcut, then you can see which entry you need to revert.
Here is where you click to access the right template entry:
This takes you to your template editor, a modified template entry is identified as having a blue dot after it, you can always rightclick that and delete - this will restore the ClickLearn template default:
Likely, what you are after is a similar looking entry, but with “after” in the name - or something similar to that.
