Using ClickLearn from iPads
  • May 13, 2021 2:25 PM UTC
  • 127 views
trice602
Forum|alt.badge.img+2
Question:
I am publishing my content to OneDrive.  I have a group of users that are on iPads and want to watch the videos and use the “shelf” on an iPad.  What options are available to make this happen.  Thank you for your time!
Please note:  I will not be producing any content on an iPad, just watch videos and using the content published on the shelf.
Thank you for your time today!
anytime! let us know how that webserver works out for you :)
  • May 18, 2021 4:12 PM UTC
Hi @trice602
If you are not able to access the OneDrive content from an ipad, then i suggest putting it on a webserver instead.
The easiest will be to publish it to either the ClickLearn cloud, or another web server - then access it from there.
The content is written to scale to all sorts of devices, though some may require that scaling / panning is enabled in the video.
trice602
  • May 18, 2021 8:28 PM UTC
  • May 18, 2021 8:58 PM UTC
trice602
  • May 21, 2021 9:44 PM UTC
Working great Morten!  Thank you!
