Why does Click Learn not record my clicks?
  • Aug 19, 2021 8:12 AM UTC
  • 198 views
I have been recording some processes and have waited for the green box to appear before I click the links in the process I am doing and once recording is done, Click learn only recorded around 3 of the actions over 10 actions.I am working on IFS Aurena. I have installed the google chrome plug in.
hi @jasminesai
Sorry to hear of your issues :/
Are you using a trackpad, the built-in mouse in your laptop? This input device is not considered a raw input due to the way Microsoft handles the driver portion.Clicklearn is set to record raw input by default, while this can be changed - it is NOT recommended.
Please try using an external USB mouse instead, and let me know if that does not resolve your issue .)
  • Aug 19, 2021 10:59 AM UTC
hi @jasminesai
  • Aug 20, 2021 9:28 AM UTC
I was using a laptop track pad. Now I am using a mouse, it is fixed now. Thanks!
  • Aug 20, 2021 10:47 AM UTC
great to hear :)
