Morten's Corner - How to Qualify and Ready a recording for UXP
  • Aug 30, 2024 2:23 PM UTC
  • 2 replies
  • 239 views
Learn how to perform quality assurance for the recordings you are using with the User eXperience Panel and even evaluate if they are eligible at all.
TIMESTAMPS
00:00:24 - scope of today
00:00:47 - Scenario 1: Data selection
00:05:33 - Scenario 2: Navigation implementation
00:07:35 - Scenario 3: User Role selection
00:10:10 - Best practice and takeaways
  • Sep 4, 2024 8:05 AM UTC
Really useful guide thanks. Regarding scenario 1 re data selection, good to see the workaround. Just to check I’ve understood right, are you saying it wont select the account (Mortens store) just because it now has a phone number? Even though it is the same account?
I have generally toggled it to select any row in the editor, would this not work?
Edit - I think I have not had this issue because I have recorded guides using accounts that have full data including phone numbers. I tried deleting all the phone numbers in an account and the assist worked ok, so the reverse scenario seems to be ok.
  • Sep 4, 2024 8:33 AM UTC
Hi Matt,
thank you :)
Any row / any cell will work for the assist, yes.
For a replay however, it will not - then you need specific data. Meaning if you ever were to update your instruction you would have to go through the recordings again and adjust them, rather than just be able to replay them at will since they are pre-adjusted so to speak :)
Using any row in combination with current row is a good mix of having a flexible assist and a working replay.
