Automated Process Testing using ClickLearn Attain
  • May 21, 2021
  • 672 views
Witness the world premiere of Automated Process Testing (APT) in ClickLearn Attain. Use your existing recorded processes or new recordings as the basis for setting up end-to-end testing, across applications and platforms. The ClickLearn Attain May release launches with a full graphical user experience for hooking up even complex testing scenarios. If you are looking for reassurance that your upgrade project will not impact your entire business, APT may very well be the must-see session:
  • Using existing work instructions (recordings) as the basis for APT
  • Setting up APT with decision forks, assets and screen-capturing features
  • Using variables and functions to customize your testing
  • Binding multiple test scenarios together
  • Executing tests and reporting results
