Business Central and Green Box not in the right place
  • Oct 20, 2022 5:55 PM UTC
  • 109 views
When using Business Central in Chrome, with Click Learn, the green box appears above the spot where the click should take place. If we put the mouse over items in the quick links(Top of teh screen), the green box appears 2 inches too high. If we put the mouse on the cue cards, the green box appears too high over the cue card.
strange item - If I have teams sitting over Chrome’s screen(stacked on top of), then the box correctly tracks to the right location.
Strange Item - Other applications have the green box show up correctly.
Installed - Chrome connector and Chrome Assist are installed.
Hi @Shlandy
It can either be a scaling issue, or it can just be Chrome acting up.
Please check that your scaling is set to 100% on all connected monitors, if you do change the scaling - you need to restart your pc.
In case of Chrome acting up,  try Microsoft Edge - you can find the extension here:
https://microsoftedge.microsoft.com/addons/detail/clicklearn-connector/glfnkokmpphdldkdlbhmlnekdlgiomfd
  • Oct 21, 2022 8:21 AM UTC
Hi @Shlandy
