Scaling on a frame by frame basis
  • Oct 19, 2020 1:45 PM UTC
  • 144 views
I am using ClickLearn primarily for videos, which will then be played within our Customer Support Portal (we use Zendesk).
I would like to be able to switch between a full screen view and the zoomed in scaled view on the video.
For example, on one step in my video, I am explaining how to add an item to a sales quote. I have the text read as part of the note attached to a group of steps.
The full screen is shown In the background.
I then show the video just clicking through the columns that I explained in the text, but I don’t have narration here.
I would like to zoom in only on that step, and then maybe add a callout or highlight to the columns being clicked.
Does anyone know how to do this?
Hi @amygracer :)
i’m thinking that you could perhaps do a screenshot of the zoomed in image of those columns / the step you want.
Then, in the editor you can hide that part from the written content, and hide the written bit from the video so that you have 2 layers effectively.
Send me a mail on support, and we can look at how we can best accomplish this, or somthing close to it at least :)
  • Oct 20, 2020 7:09 PM UTC
Hi @amygracer :)
  • Oct 20, 2020 7:18 PM UTC
Thanks, Morten. That’s exactly the workaround I’ve been playing with :)
Is the zoom frame by frame going to be available in Attain?
  • Oct 21, 2020 2:20 PM UTC
Hi Amy,
ah, cool - look at you go :D
currently it is not an option in Attain, but its a great idea - perhaps you can suggest it here? :)
https://community.clicklearn.com/ideas-feature-requests-62
Please use the ClickLearn Attain tag when you create it :)
